AP1200 and WPA2
Oct 9th, 2008
Hi all,
I need to analyse options for starting using WPA2 with our Wireless network. I have been looking around Cisco web site, but can not find definite answer if our kit can be upgraded (hardware and/or software) to support this.
We have mixture of following two APs:
Cisco AIR-AP1220-IOS-UPGRD (PowerPC405GP) processor with 15038K/1336K bytes of memory.
Product/Model Number: AIR-AP1220-IOS-UPGRD
System Software Filename: c1200-k9w7-tar.123-8.JA2
System Software Version: 12.3(8)JA2
Cisco AIR-AP1231G-E-K9 (PowerPC405GP) processor (revision A0) with 15038K/1336K bytes of memory.
Product/Model Number: AIR-AP1231G-E-K9
Additionally all APs have radio upgraded to 802.11g by by replacing original radio cards with AIR-MP21G-E-K9 cards.
The main questions I need answered are:
1) Will our current 1200 Aironets support WPA2 with upgrade (hardware and/or software)?
2) If yes, what needs to be upgraded?
I would appreciate help with this.
Sasa
Overall Rating: 4 (1 ratings)
scottmac Thu, 10/09/2008 - 05:20
  • Green, 3000 points or more
Check the hardware rev of your radios.
Earlier generation radios cannot support WPA2.
Post up what flavors of Hardware (radios) you have.
You can find that information from the details tab of the WebGUI for each radio.
jeff.kish Thu, 10/09/2008 - 06:14
  • Silver, 250 points or more
My understanding from Cisco was that, if you have 802.11g radios, you can use WPA2 via a software upgrade. But I'd still do as Scott says and either post or research your model numbers to find out for sure.
The 1231s aren't a concern - they can certainly use WPA2 with an IOS update. The 1220s are the concern for whether the upraded radios can support such a software upgrade or not.
sasaadamovic Thu, 10/09/2008 - 07:51
ScottMac and jeff.kish, thanks for your help.
I have confirmation from our Cisco support that our equipment supports WPA2 and got it working. It is just confusing as there are Cisco documents with conflincting information.
Sasa
scottmac Thu, 10/09/2008 - 12:52
You're welcome, and thank you for posting that you resolved the issue.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
