MPLS VPN over Ipv6
Answered Question
Oct 9th, 2008
I am trying to implement MPLS VPN's with IPV6. This is what I want:
1) There should not even be a single IPv4 address on the network.
2) Amongst P and PE's I want to use OSPF v3 for the distribution of labels.
3) Do the normal MP-BGP between PE's.
Is it possible to do it without any IPv4 on the core n/w.
If so then can someone gve me some links on how do I go about doing them.
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Saurav,
as far as I know this is not possible up to now.
6VPE allows to have VPNv6 over an MPLS/IPv4 core
see
Restrictions for Implementing IPv6 VPN over MPLS
6VPE supports an MPLS IPv4-signaled core. An MPLS IPv6-signaled core is not supported
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-ov_mpls_6vpe.html#wp1054029
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
dara111983 Thu, 10/09/2008 - 22:09
yes,
The LDP extensions yet don't have support for distributing the labels for the IPV6 prefixes.
Dara
saurav.khanna Wed, 10/15/2008 - 10:40
Yeps agreed I read it again and it seems the LDP is not supported with IPv6 thanks for replying. :-)
