line protocol is down VSS SUP 720 10 G
Oct 9th, 2008
Dear tech experts
I have 2 cat 6509 switch with sup 720 10G
I have formed VSS in this switches in redundant mode working fine.
after testing when I connect my PC in any one of the cat 6509 and assign access port line protocol shows down
2. I have connected the edge switch in 6509 inand I made trunk with the cat 6509 switch
but still ethernet line protocl down
Please shower all your inputs so my PC or edges switches can work with this
dabels Thu, 10/09/2008 - 11:01
can you cut and past a show interface for the port that you connect your pc to? also a show run int (and that interface number ) would help as well...
samerhabbouch Fri, 10/10/2008 - 00:45
Dear dabels
thanks for caring
core 1
switch virtual domain 100
switch 1
int port-channel 1
switch virutal link1
int gi5/4-5
channel group 1 mode on
no sh
VSS with othher peer working with this commands
now the interface config for the pc
int gi1/1/1
switch port mode access
switch port access vlan 230
no shut
pc line protocol never comes up
please see attach ment as well
dabels Fri, 10/10/2008 - 04:50
Have you added vlan 230 to the config?? looks like this may be your problem. in config mode type int vlan 230 enter and then you can do a ctrl z and then check it.
