Cisco 851 and PPPoE
Oct 9th, 2008
I have a Cisco 851 and try to configure PPPoE to my provider. IOS 12.4(15)T7. And there are no interface command 'pppoe enable' in this IOS. What can I do? Without this command nothing is working (see the attachement).
Collin Clark Thu, 10/09/2008 - 06:31
  • Purple, 4500 points or more
Here's is a working config for PPPoE.
interface FastEthernet4
description Physical Connection to Internet
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer0
description OUTSIDE
ip address 75.x.x.x 255.255.255.248
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ntp disable
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password 0 MySeCrEt
Hope that helps.
kondratev Thu, 10/09/2008 - 18:05
I can't enter the command 'pppoe enable group global'. There are no this command in my IOS!
Scott Cannon Mon, 10/13/2008 - 20:18
remove the group global part of the command and just use pppoe enable.
eg:
int fa0/0
pppoe enable
int dail0
ip address negotiated
ip mtu 1492
dial pool 1
yaminqureshi Wed, 10/15/2008 - 02:20
I am having the same problem with the version Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3) on the other hand this command is showing up fine in the version Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4).
Is that relate to the problem with the version of IOS?
Thank you
Yamin
