Warning message
Problem with static NAT
Oct 9th, 2008
I have a problem with implementing NATing on my cisco 1841 router. If a apply one to one mapping, only the first mapping works. Below is my config. will be grateful to have your assistance;
CONFIG:
interface FastEthernet0/0
description LAN_Interface
ip address 10.195.1.20 255.255.252.0
ip nat inside
duplex full
speed auto
interface FastEthernet0/1
description WAN_Interface
ip address 196.201.34.63 255.255.255.128
ip nat outside
duplex full
speed auto
ip default-gateway 196.201.34.3
ip classless
ip route 0.0.0.0 0.0.0.0 196.201.34.3
ip route 192.168.1.15 255.255.255.255 10.195.3.1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static 192.168.1.15 196.201.34.45
ip nat inside source static 10.195.1.21 196.201.34.50
ip nat inside source static 10.195.72.10 196.201.34.51
ip nat inside source static 10.195.2.103 196.201.34.62
snmp-server community kasapa RO
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
