LMS 3.1 - Installation
Oct 9th, 2008
I've just installed an evaluation copy of LMS3.1. I performed a discovery and wanted to take a look at the map.
When I click any link for "Topology Services" I get a pop-up, which then imediatly closes.
If I open up Campus Manager and go to the Visualization Tab and "Launch Topology Services", then the PLug-in is downloaded, JAVA starts and then I get a pop up saying "Cannot Connect to ANI server: null" Cause unknown error.
I've checked the ANI Server Service and it indicates that it is running, but with the Busy Flag Set.
I would be grateful for any help. or is tha ANI Help.
Cheers
Stuart
Joe Clarke Thu, 10/09/2008 - 07:17
Make sure the TCP ports 42342 and 43242 are open between client and server.
smunro-nsx Thu, 10/09/2008 - 07:30
Not sure I follow. Do you mean ensure there are no extended ACL's been the Client & Server? or you mean open up the Ports on the server to accept connections on those ports
If the first, then I have no ACL's on the network between the Client & Server.
If the second, can you tell me how I do that.
Thanks much,
Stuart
Joe Clarke Sat, 10/11/2008 - 09:24
I mean make sure there are no firewalls or ACLs blocking those ports between client and server (this includes any host-based firewalls as well). You should be able to telnet to both of those ports from the client, and get a successful connection.
