Warning message
PIX IOS upgrade
Answered Question
Oct 9th, 2008
I have a PIX 515 with IOS 6.3.
1) I'm trying to upgrade to IOS 7.0 but can't seem to find the download for it. All I see here is router IOS: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268438303
Are they one in the same?
2) When I upgrade from 6.3 to 7.0, what major alterations will I need to make to the existing running-config? Right now it is a pretty basic firewall. Basic port forwarding, statics, and a few VPN user groups are in, but that's about it.
Thanks for any help.
Still learning the Cisco Firewall side of the world.
Correct Answer by JORGE RODRIGUEZ about 8 years 10 months ago
Scott,
If you have cco access to download area go directly here. The code for PIX platform is found here as well.
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
Also from the same link above another link, this one to provide you with all you need to know requirements, depricated commands etc..prior to upgrading code.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 10/09/2008 - 04:29
  • Green, 3000 points or more
Scott,
Rgds
Jorge
scott.bridges Thu, 10/09/2008 - 05:24
Thanks, Jorge!
That's exactly what I needed!
I have no idea how you found that link, but I was searching all of Cisco's site. Gah.
Thanks again!
