Unity Blind Transfer via PIMG problem
Answered Question
Oct 9th, 2008
I have a Unity 5.0(1) server we've just setup to replace our existing system. I have it connected to one of our NEC NEAX 2000 IPS PBXs via a Dialogic PIMG 1008LS with serial integration through the PIMG.
I have integration working and most everything seems fine. But if I call Unity and enter an extension the blind transfer fails.
If I watch on the port status monitor is shows it tries a xfer then plays the subscriber greeting then hangs up and the caller ends up getting the opening greeting. During all that the caller only hears MOH with a brief cut out and the subscriber extension never rings.
I'm hoping I'm just missing something easy.
Correct Answer by eschulz about 8 years 6 months ago
Traces from the PIMG might tells us more but my initial guess would be that the PBX is sending a special (stutter?) dialtone when PIMG does the hookflash to initiate the transfer. PIMG could see this as an error tone rather than dialtone, which would cause the transfer to fail.
-Eric
Overall Rating: 3 (1 ratings)
Correct Answer
eschulz Thu, 10/09/2008 - 07:23
  • Cisco Employee,
-Eric
culittle Thu, 10/09/2008 - 07:57
  • Cisco Employee,
Yes, we will need all the Tel traces from the PIMG
nweddle Thu, 10/09/2008 - 09:01
I looked at the PIMG config page again and there is a "Wait for dialtone after flash hook" setting. It's not mentioned in the setup manual. I set it to "No" and now it works. So it looks like your guess was right.
Thanks for the help,
Nathan
