FTP Head Ache (Multiple ADSL lines)
Oct 9th, 2008
I'm hoping someone will be able to help me with a solution to my problem.
I have a CISCO 2811 running IOS 12.4 and 4 ADSL lines unfortunately not bonded so have seperate public IP addresses. NAT and CEF as been setup so that traffic is pretty much balanced over all 4 lines.
The problem is FTP, connecting to a server using standard ports is either very slow to connect or times out when trying to connnect for "data". I have tried shuttind down all but one interface and it works fine, as you bring up the interfaces the delay gets bigger. I suspect the problem is that sometimes the data channel traffic is getting sent down another line and therefore has a different IP address which means it gets blocked by the FTP service because it hasnt been authenticated. I may be wrong though.
I can't work out how to resolve the problem. I thought of an alternative way trying to force all FTP trafic down one line which isn't ideal but would do as a temporarly work around, but I cant get it to work.
Basically what I am doing is creating two ACL's like so
ip nat inside source route-rmd0 interface Dialer0 overload
ip nat inside source route-rmd1 interface Dialer1 overload
ip nat inside source route-rmd2 interface Dialer2 overload
ip nat inside source route-rmd3 interface Dialer3 overload
access-list 115 deny tcp any any eq ftp
access-list 115 deny tcp any any eq ftp-data
access-list 115 permit ip any any
access-list 6 permit 192.168.1.0 0.0.0.255
route-map rmd3 permit 10
match ip address 6
match interface Dialer3
route-map rmd2 permit 10
match ip address 115
match interface Dialer2
route-map rmd1 permit 10
match interface Dialer1
route-map rmd0 permit 10
match interface Dialer0
But this doesn't seem to resolve the problem either.
Anyone got any bright ideas?
l33h3lluk Fri, 10/10/2008 - 01:08
I had looked at this and couldn't seem to work out how to make it work for my setup.
After some more surfing I have tried the following which still doesn't quite work. FTP was still doing the same and infact normal internet traffic was being killed.
interface FastEthernet0/0
ip policy route-map ftproute
route-map ftproute permit 10
set interface Dialer3
route-map ftproute permit 20
I know what I need to do but can't seem to find an example how to do it.
I need to apply the route-map policy to "in" coming traffic on the FastEthernet so if its FTP then its set to use Dialer3 as the interface otherwise drop to the empty
Then use the route-maps assigned to the outgoing interfaces.
which are all now assigned
match ip address 6
I did try doing using "ip policy route-map ftproute in" on the FastEthernet0/0 interface but thats not valid. Am I getting warmer?
Lee
milan.kulik Fri, 10/10/2008 - 07:31
how excatly does your config look like?
IMHO, you just need to revert ACL 115 to
access-list 115 permit tcp any any eq ftp
access-list 115 permit tcp any any eq ftp-data
Then
And that's all for PBR.
If your NAT works correctly for NATing the outgoing packets to the address of outgoing interface by
it should work.
BR,
Milan
l33h3lluk Fri, 10/10/2008 - 07:45
Yea my last change that I made to access-list 115 was as you have just mentioned.
I also tried
access-list 115 permit tcp any eq ftp any
access-list 115 permit tcp any eq ftp-data any
Doing either of these just kills the internet connection and makes no difference to the FTP problem.
Is this because traffic thats returning out of the FastEthernet back towards the lan is having to be tested against this policy?
Can you just only get the policy to be applied for traffic leaving the lan towards the internet which I assume would be FastEthernet In?
Any other ideas?
Also any ideas about the original problem allowing FTP to work down any line? Surely other people must have faced a similar problem?
Lee
milan.kulik Fri, 10/10/2008 - 08:02
my PBR understanding is it's always applied to IN traffic on the interface.
The problem might be cuased by a passive FTP or something like that.
I'd try to configure the ACL to permit all traffic from your device IP and see if FTP works.
If yes, you can tune the ACL to permit FTP traffic only.
BR,
Milan
l33h3lluk Fri, 10/10/2008 - 08:09
The problem with that ofcourse the condition will always be met and all traffic will be sent to Dialer3 won't it?
milan.kulik Sun, 10/12/2008 - 11:01
Yes,
but if you configur it for one IP only and it works fine, you can investigate was was wrong with the previous ACL based on ports.
BR,
Milan
l33h3lluk Mon, 10/13/2008 - 00:04
Sorry I don't quite follow,
Could you give an ACL example please.
Lee
milan.kulik Mon, 10/13/2008 - 00:39
my idea was following:
Let's say you are connecting from one PC in your LAN (192.168.1.10, e.g.) to an Internet FTP server.
If you configure
access-list 115 permit tcp host 192.168.1.10 any
and use it for your PBR, you could force traffic from that PC to use Dialer3 as the outgoing interface.
If you notice no problem with your FTP connection this way, you could modify the ACL to permit all FTP traffic outgoing from your LAN (this might be more than just access-list 115 permit tcp any eq ftp any
access-list 115 permit tcp any eq ftp-data any, if passive FTP transfer involved, e.g.).
Running Ethereal, e.g., on your PC would help you to identify what's necessary to permit by the ACL.
BR,
Milan
l33h3lluk Mon, 10/13/2008 - 00:51
I assume if I do this, no one else will be able to use the internet while I'm doing this as they would get a deny ACL wouldn't they?
Lee
l33h3lluk Mon, 10/13/2008 - 00:59
Ignore that last post, still early and need a few more cups of coffee.
milan.kulik Mon, 10/13/2008 - 01:02
if you use
the traffic which is denied by ACL 115 goes to the next route-map section whis is doing nothing with it, i.e, it should be sent by the standard routing procedure.
BR,
MIlan
l33h3lluk Mon, 10/13/2008 - 01:04
Yea thats what I released when the coffee started to kick in.
Forcing my connection to use Dialer3 using PBR like you said seemed to do the trick.
So I guess the question hows the best way to resolve the problem for everyone
I have just tried again using PBR for ftp and ftp-data and it just kills the internet performace. Just don't get it, it should work.
Lee
l33h3lluk Mon, 10/13/2008 - 05:17
Yea I have been using Wireshark which replaces Ethereal although its not really told me alot that I don't already know.
I had a look at the NBAR stuff but couldn't see anyway to use it how I need to. You can't seem to (well not obviously) be able to specify a policy that matches FTP traffic to use a certain interface.
Can't believe it can be this difficult to get working.
Lee.
Giuseppe Larosa Mon, 10/13/2008 - 12:10
Hello Lee ,
No, this cannot happen :
the FTP is sourced by using a single public address once that is chosen a NAT entry is created and also the data connection is constrained to use the same IP endpoints.
I hope you are not using any per packet load-balancing command in your router that could be a problem
Are you using also CBAC or other security measures that could affect the FTP sessions setup ?
Hope to help
Giuseppe
l33h3lluk Thu, 10/23/2008 - 07:14
Hi Azharmirza,
No success so far.
In the end we have got a some Cisco Partner looking into it, although that was end of last weekend and still no resolution.
I spent over week trying to get my head around IOS but never really got no where. In response to giuslar, apparently can happen the engineer from company was watching traffic and the return would come in on a different dialer. We are using CEF which apparently should do load balancing per stream. *Shrugs*
azharmirza Fri, 10/24/2008 - 04:52
I solved this for my seup. I had exactly the same setup as mentioned in the 1st post. I used a dirty hack using EEM.
As the ftp session open multiple flows it always goes through the 1st & then 2nd dialer and connection is reset.
I created a policy route-map ftp1 to match ftp traffic & force out via dialer 1 but also tracked dialer 1 state and if dailer 1 goes down, EEM will automatically change the cli config to set interface to dialer 2 (when dialer 1 is down). For this i created another route-map to set interface via dialer 2. For me it works... I also changed "ip cef load-sharing algorithm original"
If you require any more info please let me know.
[email protected]
l33h3lluk Fri, 10/24/2008 - 05:02
Hi azharmirza,
Could you post any examples of what changes are needed to get it working.
Lee.
l33h3lluk Mon, 11/10/2008 - 07:26
Just an quick update. Updating IOS to 12.4(18) resolved the issue.
