Can we modify @removable?
Oct 9th, 2008
We are currently using CSA to prevent writing to USB drives by using "@removable" and defining a file set for USB (directories matching @ removable).
This has caused a problem when using App-V-formerly SoftGrid to virtualize Adobe Eeader.
App-V uses a Q drive when virtualizing applications. Evidently Q is seen as belonging to @ removable.
In testing, I have changed the file set for USBs to be directories matching @removable but not Q:\**.
This allows Adobe Reader to work without interference, but also allows pdf documents to be written to USB drives.
Is there a way to directly modify @removable? so that it does not include specific drive letters?
nexusiscco Fri, 10/10/2008 - 10:48
Tim,
Did you ever get an answer for this?
Could you share with me how your rule-module is?
Someting like custom rule-module with a deny all users to @removable\**\*.*
asp13 Tue, 11/25/2008 - 16:40
actually you can block 'usbstore' driver so no usb disks are recognized at all. I'll try to find the exact rules if it's still needed.
aman.diwakar Thu, 01/29/2009 - 19:37
Hi asp13,
Do you have that rule? I'm having some performance issues with the operating system when the USB rule is activated, I would appreciate it if you could share that rule with me so I can compare them
