Errors installing Fabric Manager 3.3.x on Linux
With the 3.3.x version of FM, PostGreSQL is the local DB that gets installed with FM. During an install on Fedora 9 I keep getting errors during the DB install portion. The errors revolve around the inability to find certain libraries. Examples are something like can't find and I've found workarounds on the net for these two particular files but during each attempt at install there is another missing file. I assume I'm doing something wrong since the FM installer should copy any needed files and there is no indication of prerequisite packages needed in the release notes or install guide. FM 3.1.3a works fine since it uses a different DB.
inch Thu, 10/09/2008 - 18:19
You prob will have to install the libcompat packages to try and drop the "version" down to something like RHEL4 or RHEL 5.
Can you paste all the errors during install? We then can add it to the wiki :)
Trending Topics: Storage Networking
