ACE4710 Real time Performance Monitoring
santipongv
Is there a way to see real time performance on ACE4710? Thank you in advance.
but what kind of statistics ??
Resources are the most important one to monitor.
This would tell you if you are about to die or not.
You can run 'show stats' to get a lot other information.
You could even get a show tech to get everything.
But I'm not sure what you are looking for.
Real time stats doesn't say what you need.
A show clock would also give you the stat about the clock in real time ;-)
G.
6 Replies 6
dsweeny
Level 3
Level 3
Won't a show run from the admin context to see real time performance on ACE4710?
Show runn just give you current running configuration without any statistics.
show resource usage
Are there any other commands that can give me other real time statistics?
G.
Show stats results are some of the stats I was looking for other than result of the show resource command. Thank you.
