Broadcast and multicast counters
Oct 9th, 2008
Hi, we have a C6509 and a query about some of the interface counters - ouput below
5 minute input rate 67782000 bits/sec, 20224 packets/sec
5 minute output rate 6882000 bits/sec, 5776 packets/sec
L2 Switched: ucast: 1 pkt, 114 bytes - mcast: 64 pkt, 4498 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 251526 pkt, 100628222 bytes mcast
L3 out Switched: ucast: 116260 pkt, 15704855 bytes mcast: 0 pkt, 0 bytes
309491 packets input, 121612961 bytes, 0 no buffer
Received 309489 broadcasts (643518 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
77138 packets output, 11294453 bytes, 0 underruns
As you can see the L3 out switched packets are 116260 packets
Whereas the ouput packets counter is only 77138 packets.
Can anyone tell me why these should be different, I know the L3 switched, is the h/w switched packets, but not sure what then the ouput packets is actually counting.
This is also the same for the input packets
Dave
hadbou Wed, 10/15/2008 - 05:40
  • Bronze, 100 points or more
packets input/output in the Cisco IOS sh interfaces counter command gives the total error free packets received and transmitted on the interface. Monitoring these counters for increments is useful to determine whether traffic flows properly through the interface. The bytes counter includes both the data and MAC encapsulation in the error free packets received and transmitted by the system.
