Difference between "ip default-gateway" and "ip route"?
Oct 9th, 2008
On the Catalyst switches, is it the same to use "ip default-gateway" or "ip route" to set a default route?
Thanks a lot
glen.grant Thu, 10/09/2008 - 06:49
No a default gateway is only used if you have turned off ip routing on the L3 switch . If you have ip routing turned on you would use the static default route pointing to the next hop address.
