10-09-2008 07:01 AM - edited 07-03-2021 04:35 PM
I am trying to convert Airnet 1220 AP's from thick to thin so I can use a 4400 WLAN controller. I've upgraded the AP's to the latest firmware release. When I use the upgrade tool I receive the following error in the error log.
2008/10/08 21:27:40 INFO 192.168.15.215 User has Full privilege
2008/10/08 21:27:40 INFO 192.168.15.215 Getting AP Name
2008/10/08 21:27:40 INFO 192.168.15.215 AP has 12.3(7)JA Image or greater
2008/10/08 21:27:40 INFO 192.168.15.215 Term Length configured.
2008/10/08 21:27:41 INFO 192.168.15.215 Upgrade Tool supported AP
2008/10/08 21:27:41 ERROR 192.168.15.215 AP does not have Supported Radio
The upgrade fails at this point. Is there anyway around this?
Solved! Go to Solution.
10-09-2008 08:04 AM
Unfortunately, upgrading to LWAPP requires an 802.11g radio. You'll need to physically replace the 802.11b radio with a g-radio module.
10-09-2008 08:04 AM
10-09-2008 08:30 AM
*sigh* I was afraid of that. Thank you.
10-09-2008 08:48 AM
Yeah, sorry to be the bearer of bad news :/ I should also point out that you can install an a-radio and it will also allow you to upgrade it, but either way you'll need to purchase and install a new radio.
