Netflow Problems
Oct 9th, 2008
We have 4 Cat6506E's running 12.2(18)SXF14 and want to enable netflow on certain interfaces (gigabit blade) but cannot as when configuring at the interface there are no commands available to enable netflow.
Commands already enabled are
ip multicast flow-stat-timer 9
mls flow ip full
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination xxx.xx.x.xx 9996
Can anybody help please ?
Collin Clark Thu, 10/09/2008 - 07:48
  • Purple, 4500 points or more
The interface command is ip route-cache flow
Hope that helps.
Gerard Gacusan Thu, 10/09/2008 - 07:54
If it's a layer-2 switchport, then not possible to enable netflow and i have same issue this before. Layer3 and Virtual Interfaces are supported only.
Try a "no switchport" command on the interface, ip route-cache flow becomes available.
Hope this helps ...
thanks ..
gerard
