viyuan700 Wed, 12/17/2008 - 09:28
Yes you can use IOS of 2610XM to 2620XM but not in 2620.
Taken from cisco
IOS for 2610XM
c2600-entbase-mz.124-23.bin
c2600-advipservicesk9-mz.124-23.bin
IOS for 2620XM
c2600-adventerprisek9-mz.124-23.bin
IOS for 2620
c2600-bin-mz.123-26.bin
2610XM & 2620XM use the same IOS
dezoconnor Thu, 12/18/2008 - 06:52
Try it and see what happens! The worst that will happen is you'll be uploading a new IOS via xmodem.
richard.m.gilbert Sun, 12/28/2008 - 20:46
They should have enough memory to hold both IOS in the flash. So ... load the new one then use the boot system command to point to the new IOS and see if it works. If it doesn't it will boot up in the old IOS and all you will have to do is delete the new IOS from the flash.
