We have Cisco7609 router with Sup720-3B, IOS version is 12.2SX(17). We used Netsocout probe to recive and analyze netflow statistics, but the router seems not send correct netflow packets to the probe. We captured netflow packets send from Cisco7609 and found the flow records are not valid. There is either empty source ip or destination ip. And some other fields like source port, destination port are invalid. The following are netflow related configuration on Cisco7609. Can you please help to solve this problem?
Best Regards,
mls ip multicast flow-stat-timer 9
mls aging fast time 8 threshold 128
mls aging long 1024
mls aging normal 2048
no mls flow ip
no mls flow ipv6
mls nde sender version 5
mls qos
mls cef error action freeze
ip flow-export source GigabitEthernet3/1
ip flow-export version 5 origin-as
ip flow-export destination x.x.x.x 9806
interface GigabitEthernet3/1
ip address x.x.x.x 255.255.255.252
no ip redirects
no ip proxy-arp
ip route-cache flow
load-interval 30
speed nonegotiate
service-policy input download-all_emax-2
hold-queue 1024 in
hold-queue 1024 out
interface GigabitEthernet3/2
no ip address
load-interval 30
switchport
switchport access vlan 96
switchport mode access
channel-group 1 mode on
interface GigabitEthernet3/4
ip route-cache flow
load-interval 30
no cdp enable
interface GigabitEthernet3/7
no ip redirects
ip route-cache flow
load-interval 30
speed nonegotiate
no cdp enable
interface Vlan96
ip address x.x.x.x 255.255.255.0
ip route-cache flow
