DHCP Server Assignment - Aironet 1130AG
Oct 9th, 2008
I am attempting to configure a Cisco Aironet 1130AG to use a Windows Server 2003 DHCP server for assigning addresses to clients connecting to the access point. Does anyone know how to set this option? I cannot find it anywhere.
Any help will be greatly appreciated.
jeff.kish Wed, 10/15/2008 - 11:23
  • Silver, 250 points or more
Is there something special that you want to happen? Regardless of the access points, the clients should DHCP from the DHCP server that exists on its own VLAN. If you want one DHCP server to cover multiple VLANs, simply place an "ip helper-address" on your layer 3 SVI for each VLAN that points to your DHCP server.
Let me know if there's something more complicated going on :)
minimag147 Tue, 11/25/2008 - 08:49
I'm having more or less the same problem but mine is even more low level than this. I have three 1130ag's that were setup in as PEEP authentication. The PEEP was proving to be a problem for whatever reason and we decided to go with WEP authentication and have the 1130's be regular old APs. Well apparently they can't or won't do that. I set one up as a standalone AP and it actually worked for about three weeks giving out DHCP addys to laptops then one day decided it wouldn't anymore. So I reset it using the MODE button and put the same information back into the device. Now it will allow clients to connect but never gives them a DHCP addy. We don't have and never had a Cisco Wireless controller and these have been working as PEEP WAPs for well at least a year or so. Why won't they simply give out DHCP to the clients?
