Hunt Group Problem
Oct 9th, 2008
Good afternoon!
I have a problem with an Hunt Group configured in a Cisco Call Manager 6.1.1
There are 4 DN associated with a Line Group and only two of them answer calls from the Hunt Pilot.
All the Devices have the option "Logged Into Hunt Group" checked.
Rob Huffman Thu, 10/09/2008 - 10:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pedro,
The first thing that I would check is what Distribution Algorithm you are using on the Line Group. Perhaps it is set as Top Down and you keep hitting the same two DN's. Try Longest Idle.
Hope this helps!
Rob
pedro_martinho Thu, 10/09/2008 - 10:30
Hi Rob!
I reloaded the Call Manger and it started working.
Thank you for your help.
Hi Rob!
Hi Rob!
Rob Huffman Thu, 10/09/2008 - 11:32
  • Hall of Fame,
    Founding Member
Hey Pedro,
Good stuff! Glad to hear that you got it working.
Cheers!
Rob
