Where does Unity store Alternate Extensions of a subsriber
asomanya
Unity Cisco Unity 4.0 Build 4.0(4) SR 1
I have an instance to report on all the Alternate Extensions of all subscribers of the system, and I am looking for the table/column that contains this information.
Thanks considerably,
Alex
2 Accepted Solutions
Bradford Magnani
If you open the Data Link Explorer in the Tools Depot>Diagnostic tools, look in the DtmfAccessId table, DtmfAccessId column will list all of the extensions that are both primary and alternate. Alternate extensions will have the IsPrimaryId column UN-checked.
Hope this helps,
Brad
Hey the Subcriber Information Dump is probably a better tool for what you want.
It will dump what information you want into a csv file.
It is also in the Tools Depot/Administration Tools.
It is also in ciscounitytools.com if you want more information about the tool.
Hope this helps.
Randy
Bradford Magnani
Hope this helps,
Brad
Hope this helps.
Randy
Hi Randy,
You are right that is a better tool, just saw this mail, don't know why the delay. I had to use a select statement to join both dtmfaccessid and subscriber to make sense of the report. Regards
Thanks Brad, that was quite helpful.
