How to update shared extension at the same time at 6.12
Answered Question
Before upgrade 6.12, I had 4.13.
I can update all share extension (share appearance key) by checking the box.
However, I no longer find at 6.12, can anyone tell me??
Another weird thing I find at 6.12 is that if I want to delete the shared extension, it will delete all of the them.
In other words, 1111 appears at 5 IP Phones, if I delete 1111 at one of phones, everything is gone. I have to use "Dissociate Devices" the phone first. It is pain.
Correct Answer by Chris Deren about 8 years 7 months ago
Instead of going through device to the extesnion go to it from call routing --> Directory Numbers and make the changes there to affect all shared lines.
Dont delete it from the line level, simply move the line to "Disassociate Devices" box.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Thu, 10/09/2008 - 11:55
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
