IPCC 4.0 Agent Personal Phone Book Location
Oct 9th, 2008
We are running IPCC 4.0 and it crashed the other day. Some of our users that were using personal phone books no longer have them. I imagine that they are stored on the server, but does anyone know exactly where? Is there a way to prevent this from happening again? Thanks in advance for your help.
mikram Fri, 10/10/2008 - 03:42
Did you try to restore from backup? It should populate the phonebook from last backup.
Good Luck
Cheers
Ikram
gearmisner Fri, 10/10/2008 - 05:40
Do you mean from a BARs backup? I just want to make sure we are taking about the same thing.
mikram Fri, 10/10/2008 - 05:55
Just to get the idea how your system is setup. Is the IPCCX is standalone? I mean, no HA. Also,
there is option under Tools, Backup and restore.
Look at the status, you should be able to find last known good backup file. Try to restore it and check the logs.
Good Luck
Ikram
gearmisner Fri, 10/10/2008 - 09:59
We are running in HA, but there is no option for back up and restore. Do you know where the files are stored locally on the server for example "c:\programfiles\cisco\whatever" Thanks for your guys' input. It is much appreciated.
