PIX site to site tunnel, new IP
Answered Question
Oct 9th, 2008
Hello all,
Have a NY PIX with outside IP 20.1.1.35
Have a SF PIX with outside IP 20.2.2.163
Have an existing tunnel with this:
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer 20.2.2.163
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address 20.2.2.163 netmask 255.255.255.255 no-xauth no-config-mode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
I am getting a new static IP for the NY PIX, let's say 30.1.1.98
To have the tunnel still function, all I need to do is change the crypto map peer and change the isakmp key on the SF PIX?
If so, when I do "no isakmp key", do I just create a new one by "isakmp key 12345 address 30.1.1.98 netmask 255.255.255.255 no-xauth" ?
Thanks for any help!
Correct Answer by Jon Marshall about 8 years 3 months ago
"To have the tunnel still function, all I need to do is change the crypto map peer and change the isakmp key on the SF PIX?"
Depends on what your access-list is doing ie. outside_crypto_20. if you are natting the private IP addresses to the public IP these would need updating as well.
If not you are correct that should be enough.
To remove the key
no isakmp key ******** address 20.2.2.163
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 10/09/2008 - 17:56
To remove the key
Jon
scott.bridges Thu, 10/09/2008 - 18:08
access-list outside_cryptomap_20 permit ip 192.168.1.0 255.255.255.0 192.168.16.0 255.255.255.0
That is the ACL. The LAN IP scheme isn't changing, so I'm not seeing a reason to change this up. Is this a correct assumption?
All that is changing is the outside IP address.
If so, thanks so much for your help!
