JORGE RODRIGUEZ Thu, 10/09/2008 - 17:08
  • Green, 3000 points or more
it could be software issue, I would suggest to load/install a new fresh IOS code, if you are getting a forced software crash reload which seems like the router is reloading in a loop bring the router to rommon> and install new image, try installing a different version from the current running version.. in the event that after reloading router with new image and do have same issue it could then be hardware, I have seen similar issues caused by software bugs or corrupted IOS codes and have been solved by reloading fresh code, try that.
Jorge
arianto.wibowo Thu, 10/09/2008 - 19:25
hi,
there's an error msg "Unexpected NM Interrupt received from slot: 1".
may be you can try to unplug the module and reload again.
cheers.
sujitkr7cisco Fri, 10/10/2008 - 12:54
Ok , I did but problem not resolved.Thanks for reponse plase suggest me next step.
Sujeet
satish_zanjurne Fri, 10/10/2008 - 19:23
  • Silver, 250 points or more
1.If you have newly installed the IOS & still it is giving problem
2.If you have removed the module, reinstalled & rebooted , still it is giving problem.
3.If you have removed the module , & then booted the router, but still it is giving problem
4.Then RMA the router & get the replacement
HTH...rate if helpful..
