LMS recommended servers specs for LMS3.0
Oct 9th, 2008
We will be installing CWLMS-3.0 that will manage 1500 devices. We are planning to separate the DFM. What is the recommended specs for the first server that will hosts CS,RME,IPM and CM. and specs for server 2 that will run DFM? which server will need higher specs?
srego4 Thu, 10/09/2008 - 18:56
i'd suggest keeping RME and CM apart. these are the two biggest resource users.
but if you do try to set it up the way you want, you'll need 8GB ram/dual cpu & above/min 80GB (get much more than that) on the first server. DFM alone...i believe can live with 2GB.
