EIGRP error not on common subnet
Oct 9th, 2008
Oct 10 05:44:41 GMT: IP-EIGRP(Default-IP-Routing-Table:100): Neighbor 172.19.242
.74 not on common subnet for GigabitEthernet0/1.6
please discuss why this arises and how to overcome.
Giuseppe Larosa Thu, 10/09/2008 - 22:49
  • Hall of Fame,
    Founding Member
Hello Abhay,
this means there is a router with an interface or subinterface in the L2 vlan associated with local router int g0/1.6 that is sending EIGRP hellos with right parameters (AS number k values) but using a source address that is not part of IP subnet on local router interface g0/1.6.
This check is performed by EIGRP to verify that the neighbor can be safely used as an ip next-hop.
ip 172.19.242.74 is out of local subnet.
If you want to build EIGRP adjacency: modify remote router ip address to fit or change the network mask on local router to be able to accept ip 172.19.242.74
Hope to help
Giuseppe
csco10716389 Thu, 10/09/2008 - 23:21
Giuseppe
thanks for replying but the subnet is not the issue here , as mentioned by u (source address is not a part of ip subnet on local router)i have verified it is contained in the same subnet,main interface g0/1 doesnot have any ip adress it is a trunk port and the sub interface G0/1.6 is connected to Layer3 switch and the port on which it is connected it has been assingned a vlan.now i think it is clear and now explain what could be the issue
