Excessive collision in the Router
Oct 10th, 2008
Hi All in Router i am the getting error:AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=1, TRC=0
Router is connected to Switch, both router and switch config is below
can some body tell me how to fix up this issue as i am planning to change Duplex setting router from half duplex to full duplex
will this solve my problem
Router config:-
interface Ethernet0/0
description ### LAN ###
ip address 10.21.1.2 255.255.0.0
ip access-group 141 in
ip route-cache flow
half-duplex
standby ip 10.21.1.1
standby preempt
end
Switch config
interface GigabitEthernet0/1
description ***FREE***
no logging event link-status
no snmp trap link-status
no mdix auto
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree guard root
Erros
Overall Rating: 4 (1 ratings)
Jon Marshall Fri, 10/10/2008 - 01:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes. Either change both to auto neogotiate or change the router to full duplex.
Jon
UCBNOCWAN Fri, 10/10/2008 - 01:10
Is it necessary to change on Switch side as i belive switch can do auto negotiate and also no speed settings has defined on the swtich side
Jon Marshall Fri, 10/10/2008 - 01:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you want to auto-negotiate then set the router interface to auto-negotiate ie. get rid of the "duplex half" statement.
I would do as Andrew suggested though - set both to 10full.
Jon
UCBNOCWAN Fri, 10/10/2008 - 01:18
Thanks for the replies,
but this router suports only full Force full duplex operation//half Force half-duplex operation
So please let me know is it required to change at swtich end also
Jon Marshall Fri, 10/10/2008 - 01:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you are setting the router interface to full duplex then do the same on the switch port.
Jon
UCBNOCWAN Mon, 10/13/2008 - 01:14
Dear All,
Thanks very much for the all for giving the replies.
lastly will be there any impact on the network interms of outage if executing this change on both router and switches
Jon Marshall Mon, 10/13/2008 - 01:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes, traffic will be disrupted when you make the change. Probably best to do it out of hours.
Jon
UCBNOCWAN Mon, 10/13/2008 - 05:23
Thanks Jon,
Willbe doing the change after business hours, could you please let me know how much will be the down time
Jon Marshall Mon, 10/13/2008 - 08:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
It's more of quick interruption in traffic forwarding rather than full downtime. About 1 min per change should be more than enough.
Jon
peter sithole Sat, 11/19/2016 - 01:47
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
