CM6.1 - Microsoft Exchange 2007
Oct 10th, 2008
Hi!
When I call to the voice mail I get a busy signal back. It has worked before.
The event viewer log from the Exchange server displays the following message: "the unified messaging server rejected an incoming call with ID ......@x.x.x.x" Reason "Cannot find a valid UM IP Gateway for x.x.x.x..."
Any idea why is this happening? There has been some new configuration for the OCS installation.
Ana
tim.giles Fri, 10/10/2008 - 02:26
  • Silver, 250 points or more
I'm not a 2007 expert but found a relevant document on google. It might be worth checking the details here to make sure the IP address is correct in Exchange Management:
http://64.233.183.104/search?q=cache:6TVYevPTUkoJ:blog.lithiumblue.com/2007/04/accessing-exchange-2007-unified_8286.html+Cannot+find+a+valid+UM+IP+Gateway&hl=en&ct=clnk&cd=5&gl=uk
Hope this helps.
MARTIN STREULE Fri, 10/10/2008 - 03:41
Are you sure that the UM IP Gateway is (still) configured in Exchange?
Is the dialplan okay?
abartolomeu Mon, 10/13/2008 - 01:50
Hi!
In Exchange it seems to be everything properly configured as in the CUCM!
I would like to do some further troubleshooting like for example have some logs. What do you advise? /var/log?
Meanwhile there is something that I've noticed that I'm not sure if could be the problem:
On the administration UI, “System  Licensing  License Unit Report” I've confirmed that the license file is uploaded but the status does not indicate Ready.
Best Regards,
Ana
