Syslog server for access points
Oct 10th, 2008
On the controller, when you look at an access points config. There is the syslog server for the access point with the default ip address of 255.255.255.255. I was wondering if there was any way to disable the syslog server for the access points. The only thing I've found so far is that the ip address of the syslog server can be changed.
didyap Thu, 10/16/2008 - 10:35
  • Silver, 250 points or more
To remove a syslog server, use the no logging host global configuration command, and specify the syslog server IP address. To disable logging to syslog servers, enter the no logging trap global configuration command.
Pravin Phadte Tue, 01/06/2009 - 23:19
i am not sure if "no" command works.
but on 5.2 ver
config logging trap disable global
disbale/ enable is the key to set the ip address for syslog server
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
