"ip sla" usage
Answered Question
Oct 10th, 2008
I am trying to setup "Dynamic Failover with IP SLA" per the instructions detailed here: http://www.ciscoblog.com/archives/2008/08/dynamic_failove.html
I am getting an error when I try to enter the number one (or anything after 'ip sla')
% Invalid input detected at '^' marker.
Do I need to turn something on first, before I use this?
ER
Correct Answer by Edison Ortiz about 8 years 7 months ago
Always rely on the online help. If you add the monitor option, you will be able to complete the command:
http://www.cisco.com/en/US/docs/ios/ipsla/command/reference/sla_02.html#wp1027930
IP SLA configuration varies among IOS releases. Either rely on the online help or hit the IOS documentation for any variation of the command.
HTH,
__
Edison
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 10/10/2008 - 06:31
  • Hall of Fame,
    Founding Member
Please post the output from typing show version
Also, the output from the following command:
ip sla ?
HTH,
__
Edison.
epohxavrio Fri, 10/10/2008 - 07:02
I have attached two files for Router 1 and Router 2.
Output for *ip sla ?*
Router1(config)#ip sla ?
monitor IP Service Level Agreement Monitor
Correct Answer
Edison Ortiz Fri, 10/10/2008 - 07:08
  • Hall of Fame,
    Founding Member
HTH,
__
Edison
epohxavrio Fri, 10/10/2008 - 07:20
I see. I did try that.
This is what I typed...
*ip sla monitor 1*
which brings me into a config mode...
Not sure what to enter once I get in there.
Edison Ortiz Fri, 10/10/2008 - 07:39
  • Hall of Fame,
    Founding Member
After typing ip sla monitor 1 you will enter into the SLA subconfiguration, please take a moment and read the documentation from your IOS at:
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsla_c.html
Here is a sample config from that page:
ip sla monitor 6
type echo protocol ipIcmpEcho 172.29.139.134 source-ipaddr 172.29.139.132
frequency 300
request-data-size 28
tos 160
timeout 2000
tag SFO-RO
ip sla monitor schedule 6 life forever start-time now
HTH,
__
Edison.
