ASA5510 - The XML page cannot be displayed.
Oct 10th, 2008
All, using the webvpn, I am trying to access a Dell DRAC card using a web bookmark. When I click the link which ports to https://192.168.2.3, I get this error:
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A name was started with an invalid character.
Any ideas?
Thanks!
Overall Rating: 5 (1 ratings)
Djiguidjik Wed, 07/01/2009 - 07:13
I have the same problem but your page doesn't really help me...What do you mean by a configuration problem? Where?
Todd Pula Wed, 07/01/2009 - 10:45
What device is servicing your clientless WebVPN? ASA, VPN3k, router? What software version are you currently running?
Todd Pula Thu, 07/02/2009 - 08:31
If you configure a Smart Tunnel bookmark for the Dell DRAC HTTP URL, do you see the same behavior?
Djiguidjik Fri, 07/03/2009 - 01:19
Thanks a lot, with the "Enable Smart Tunnel Option" enabled on my bookmark it's working !!
Todd Pula Fri, 07/03/2009 - 06:52
Glad to hear that this solved your issue. Please rate this post so others can find the solution.
