Directory Handler Script
Hello all,
I am running CUCM 6 BE with Unity Connection 2.0.1 on the Linux Appliance server. I am currently offering up the name search directory handler through my AA script however the default Cisco intro script is, in my opinion, badly written and I cannot change it. In past versions of Unity and Unity connect it was possible to over-write the wav files with your own script. Unfortunately I can find no way of doing it in 2.0. The alternate directory prompts and instructions that are posted on ciscounitytools.com do no good for v2.0. Additionally I called TAC to inquire and they also told me that it can't be done.
My question is, has someone found a hack that TAC will not support that I can use to change the script. If I can't fix this, I will likely have to scrap the dial by name feature which aside from the script is a great feature.
