IPSEC ISSUE.
sateeshk10
ISAKMP got stuck in reponder mode its coming up intiator mode..Is there any issue...
2 IKE Peer: 1.1.1.1
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
sateesh
andrew.prince
Level 10
Level 10
No issue - normal output for a VPN peer, the remote end just happend to initiate the VPN tunnel.
If you side inititate it, it would read:-
Type : L2L Role :initiator
HTH>
I have initiated the traffic..Still its showing responder mode only..
sateesh kumar.k
This makes no difference. You may think that you have initiated the connection; however, in this situation that is not the case.
