CCM 6.1.2, HP tools for monitoring.
Oct 10th, 2008
I am install CCM 6.1.2 and the I have HP servers. Is there any way I can install HP tools on the Linux boxes.If you, how can I do it and is it a best practise?
Thanks!
gogasca Fri, 10/10/2008 - 14:46
  • Green, 3000 points or more
Technically you can, not supported we have other third party monitoring tools, that should work
Root access required
rohanpatel Mon, 10/13/2008 - 09:52
Thanks...
So If I want to install I need to contact TAC
and get the root access or it there any other
way to do it.
Thanks!
