Do I really need a MCS server for Unity?
Answered Question
We are planning a VoIP deployment. Can I install Unity on any Windows server that meets hardware requirements? Why should I purchase an MCS system with Unity rather than, lets say, and Dell server?
One of the things I like about having it on a Windows box is that I can back it up with Backup Exec and restore it to another server in the event of a disaster.
Correct Answer by ranpierce about 8 years 7 months ago
Hi all,
If this was helpful please rate.
Randy
Overall Rating: 5 (1 ratings)
ranpierce Fri, 10/10/2008 - 10:06
  • Silver, 250 points or more
I run on my own HP platform, the only con that I see is that you need to provide your own windows CD and you will not get the Cisco Unity Platform CDs from Cisco.
It takes a little longer to install. But the servers cost less.
MCS servers are just HP and IBM servers that are branded Cisco anyway.
Hope this helps.
Randy
ranpierce Fri, 10/10/2008 - 10:55
I sent you an email offline
Randy
Correct Answer
ranpierce Fri, 10/10/2008 - 12:00
Hi all,
Randy
