Outside Interface IP address
Oct 10th, 2008
I woder if using ASA or PIX, can I set up the outside interface with 1 IP then for outgoing (on the same outside interface) with another IP address. For example: outside IP 1.2.3.4 then somehow for outgoing(return traffic if you will) the IP address to be visible is 1.2.4.5 (partner requirement, don't ask :) ).
Doing this on Linux iptable already and now is thinking to change it out to something else,i.e. ASA or PIX.
Thank you for your hep.
suschoud Fri, 10/10/2008 - 09:53
  • Gold, 750 points or more
use :
nat (inside) 1 0 0
global (outside) 1 1.2.4.5
All outbound traffic will be translated to 1.2.4.5
If you use ;
global (outside) 1 interface
Interface ip will be used for xlation purpose.
Do rate helpful posts.
Sushil
