2 VPN interfaces on the same device
Oct 10th, 2008
Hi all,
I have a bit of a dilemma. We have an ASA 5510 which we currently have some L2L and remote access VPN connections on.We brought in a higher speed line to terminate our VPN on and I need start moving VPN connections to the new interface. I overlooked one issue the default route, it won't follow the same interface it connects to back out. Can I have 2 default routes so that is sends out both interfaces? I know this is a stretch, but I am hoping someone has a solution for this.
singhsaju Fri, 10/10/2008 - 11:48
  • Silver, 250 points or more
You can create specific routes for VPN peers (moved to new interface) pointing towards the new interface. Keep the default route as it is .
route VPN Peer ip 255.255.255.255 XXX.XXX.XXX.XXX 1
I do not think two default routes would work.
Saju
Pls rate helpful posts
svanguilder Fri, 10/10/2008 - 12:55
I did that with a test connection and it did work. The L2L connections are the easy ones, it is the client based ones that are going to be an issue as there are a lot of them and trying to do a static route individually will be an monstrous task.
Anyone know much about policy based routing? Can I setup a routing policy that allows routing back out the originating interface? That would make life much easier.
