R-PVST or MST
Overall Rating: 4 (1 ratings)
Jon Marshall Fri, 10/10/2008 - 11:19
Ali
1) The network command is used to tell EIGRP which interfaces to run EIGRP on. You nearly always have this part of the confguration under your "router eigrp " configuration.
The neighbor command is used to send unicast updates to a specfic neighbor. This is not as common in the configuration.
2) MST - if you choose MST all switches should be configured with the same parameters.
R-PVST+ - you can configure 2 of your switches with R-PVST+ and leave the other 2 to run PVST+ but any vlan that exists on both R-PVST+ and PVST+ switches will default to 802.1d timers eg approx 50 seconds for convergence.
Jon
