LMS 3.1 all config related operations failing
Oct 10th, 2008
Recently there was an upgrade done from LMS 3.0 to LMS 3.1. In the LMS 3.0 there was a problem with the Inventory collection (Inventory collection jobs failing). After the upgrade the Inventory is OK, however the Config Polling, Config Collection or ArchiveMgmt all failing withthe following status for all the devices:
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> Telnet,TFTP,SSH,HTTPS
Execution Result:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
Enabling ArchiveMgmt job manually for a single device and have the app log for the ArchiveMgmt set to DEBUG gives the following:
Fri Oct 10 15:20:59 EDT 2008 ],DEBUG,[Thread-5],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,468,Total devices due for reqId = 1223664349663 is 1
[ Fri Oct 10 15:21:04 EDT 2008 ],DEBUG,[Thread-5],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,468,Total devices due for reqId = 1223664349663 is 1
[ Fri Oct 10 15:21:09 EDT 2008 ],DEBUG,[Thread-5],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,468,Total devices due for reqId = 1223664349663 is 1
[ Fri Oct 10 15:21:14 EDT 2008 ],DEBUG,[Thread-5],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,468,Total devices due for reqId = 1223664349663 is 1
The job itself sits in RMEJobs as running and cannot be stopped from the GUI, only via jobcli
Thanks for any imput on the problem
Joe Clarke Fri, 10/10/2008 - 13:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like there is a problem with ConfigMgmtServer. Troubleshooting that is not a straight-forward thing. You should open a TAC service request to get the instructions. However, to unwedge the process, simply restart it:
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
Then run your config jobs.
dmitry Fri, 10/10/2008 - 14:31
Thanks Joe, the restart of the Config process fixed the problem.
If this happens again, will open a case
