Unified Communications 6.0 CLI password
Oct 10th, 2008
I'm trying to log into UC 6.0 via ssh. I was going to try to do some custom phone backgrounds but I can't get in. I've tried the password for the ccmadmin page and still no luck. Is there a way to reset the command line password?
Rob Huffman Fri, 10/10/2008 - 12:55
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chevy,
Recovering the OS Administrator Password
If you lose the Administrator password and cannot access the system, use the following procedure to reset the Administrator password.
Note During this procedure, you will be required to remove and then insert a valid CD or DVD in the disk drive to prove that you have physical access to the system.
Procedure
Step 1 Log in to the system with the following username and password:
•Username: pwrecovery
•Password: pwreset
The Welcome to admin password reset window displays.
Step 2 Press any key to continue.
Step 3 If you have a CD or DVD in the disk drive, remove it now.
Step 4 Press any key to continue.
The system tests to ensure that you have removed the CD or DVD from the disk drive.
Step 5 Insert a valid CD or DVD into the disk drive.
The system tests to ensure that you have inserted the disk.
Step 6 After the system verifies that you have inserted the disk, you get prompted to enter a new Administrator password.
Note The system resets the Administrator username to admin. If you want to set up a different Administrator username and password, use the CLI command set password. For more information, see Appendix A, "Command Line Interface."
Step 7 Reenter the new password.
The system checks the new password for strength. If the password does not contain enough different characters, you get prompted to enter a new password.
Step 8 After the system verifies the strength of the new password, the password gets reset, and you get prompted to press any key to exit the password reset utility.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpch2.html#wp1040303
Hope this helps!
Rob
chevymannie Fri, 10/10/2008 - 13:33
hey Rob. Thanks for the quick reply. I saw this in another post and gave it a try. The username that I use to log into the administration page is ccmadmin. When I went through the process it said, your username is "ccmadmin" and it made me reenter a new a password. I tried to log into the CLI as ccmadmin with no luck but I can still get into the web page. It also gave me a choice between a password and security password. I just did the first one. Any thoughts?
Rob Huffman Sat, 10/11/2008 - 08:29
  • Hall of Fame,
    Founding Member
