hairpin route on an ASA?
Oct 10th, 2008
I have a customer with an ASA 5505 which works quite well with the one WAN outside interface connected to my ISP and the Internet and the inside interfaces connected to my LAN 192.168.19.x
The client has installed a second high-speed (& expensive) WAN link for certain traffic and wants all data going to a certain subnet to be routed out that link. That WAN link has its own NAT router and the "inside" address of that router is
I thought I could do this by just enabling hairpinning:
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
and then adding a "route inside" statement...
route inside
But that doesn't seem to work, I get an error showing up in the log:
Oct 10 2008 14:23:42: %ASA-3-305006: portmap translation creation failed for tcp src inside: dst inside:
Am I trying to do something that is simply impossible on the ASA and perhaps I should recommend a 871 ROUTER?
Any thoughts?
Farrukh Haroon Sat, 10/11/2008 - 03:12
Just exclude that traffic from NAT as it seems you have nat-control enabled on the firewall.
access-list testacl permit ip
nat (inside) 0 access-list testacl
Pleae rate if helpful.
suschoud Mon, 10/13/2008 - 07:19
Please add :
nat (inside) 1 0 0
global (inside) 1 interface
