ACS 3.3 Shell Command Authorization Sets
Oct 10th, 2008
I need help on the Authorization Set. I have the following currently configured.
clear permit port-security dynamic
permit port-security all
permit port-security sticky
permit mac-address-table dynamic
Configure permit terminal
show permit port-security
permit interfaces status
permit interfaces stats
permit running-config interface FastEthernet
permit ver
switchport permit port-security
write permit memory
permit network
copy running-config startup-config
everything seems to work fine. For example you can not do a show running config.
my problem is the conf t. Once you in you can do any commands you want ie. "int fax/x/x" "switchport access vlan XX"
I tried different interface permit commands and still can not restrict commands.
None of the permit unmatched commands are checked.
What I would like is to permit interaface commands for port security commands, but not allow shut or no shut. etc.
Overall Rating: 4 (2 ratings)
Jagdeep Gambhir Mon, 10/13/2008 - 05:16
As suggested by Faruk, it seems it is not checking for authorization in config t mode that is why you are able to execute all commands.
Please add
aaa authorization config-commands
Above command will enable authorization for config t mode.
Farrukh Haroon Wed, 10/15/2008 - 10:38
Its great to know you have it working now. :)
Please rate helpful posts to increase the utility of this information for future readers.
