TCP Reset-I in PIX Log
Since switching ISPs and having to upgrade my PIX 515 from 7.0.2 to 7.2.4 for PPPOE support, I'm having issues receiving e-mails with attachments from a particular domain. All I see in the PIX log is the following message: Teardown TCP connection 1479120 for outside:193.246.239.75/34098 to inside:10.1.255.48/25 duration 0:16:14 bytes 87079 TCP Reset-I. I'm not sure what is causing the reset.
Overall Rating: 3.2 (4 ratings)
suschoud Fri, 10/10/2008 - 13:50
  • Gold, 750 points or more
tcp reser-i suggest a reset came from your email server.You would need to look into email server to see why it is generating the reset.
Also,you can try disabling the inspect esmtp on asa,if that's enabled.
Do rate if helpful.
Sushil
suschoud Fri, 10/10/2008 - 14:53
Here you go :
considering 4.2.2.2 is the ip address of email domain to which you are facing issues sending email :
ASA5510-Single(config)# policy-map global_policy
ASA5510-Single(config-pmap)# class inspection_default
ASA5510-Single(config-pmap-c)# no inspect esmtp
ASA5510-Single(config)# access-l 101 deny ip any host 4.2.2.2
ASA5510-Single(config)# access-l 101 permit ip any any
ASA5510-Single(config)# clas
ASA5510-Single(config)# class-map myesmtp
ASA5510-Single(config-cmap)# mat
ASA5510-Single(config-cmap)# match ac
ASA5510-Single(config-cmap)# match access-list 101
ASA5510-Single(config-cmap)# exit
ASA5510-Single(config-pmap)# class myesmtp
ASA5510-Single(config-pmap-c)# ins
ASA5510-Single(config-pmap-c)# inspect esmtp
Pretty much you specify an access rule which define what traffic should be inspected by esmtp inspect.If there is a " deny " in access list,that traffic would be bypasses from inspection engine.
Do rate if helpful.
Sushil
suschoud Mon, 10/13/2008 - 07:07
Just replace :
with
access-l 101 deny ip host 4.2.2.2 any
4.2.2.2 -> ip of the domain.
Do rate helpful posts.
Regards.
Sushil
suschoud Mon, 10/13/2008 - 13:03
the suggested commands in no way can block internet traffic.
Is access-l 101 already defined somewhere in your configuration ?
Not sure what is wrong.Can u post " sh run " command output ?
Sushil
Cisco tech support suggested the below changes and that resolved the issue.
access-list esmtp_acl extended deny tcp host 193.246.239.72 any eq 25
access-list esmtp_acl extended deny tcp host 193.246.239.73 any eq 25
access-list esmtp_acl extended deny tcp host 193.246.239.74 any eq 25
access-list esmtp_acl extended deny tcp host 193.246.239.75 any eq 25
access-list esmtp_acl extended permit tcp any any eq 25
