7206VXR not tagging traffic with dot1q
Oct 10th, 2008
I have an interface set up like the following:
interface FastEthernet5/0
no ip address
duplex full
interface FastEthernet5/0.253
encapsulation dot1Q 253 native
ip address xxx.xxx.xxx.37
interface FastEthernet5/0.353
encapsulation dot1Q 353
ip address xxx.xxx.xxx.61
I cannot get the 7206 to tag traffic on the 353 VLAN.
If I do a ping xxx.xxx.xxx.62 (which should go out the 353 VLAN) my provider does not see any tagged traffic.
Why would the traffic not be being tagged??
Thank you.
Giuseppe Larosa Sat, 10/11/2008 - 00:48
Hello James,
to troubleshoot use the following
sh vlan
shows counters for each defined vlan
term mon
debug vlan packets
then issue the ping and see the results
then again
sh vlan
In this way you can also verify if provider is using ISL instead of 802.1Q if so its device doesn't understand 802.1Q tags
Hope to help
