slow network
Oct 10th, 2008
We have various small branches with cisco 26xx/16xx series connecting to the head Office Cisco 2621 via IPVPN.
Lately, the users are complainig of slow response.
Please advise the ways to diagnose and monitor the traffic.
thiru.vel10 Sat, 10/11/2008 - 09:14
Could you please let us know this 2621 router have the hardware VPN accelerator? If you using software crypto engine means it will take more cpu process due to that your performance will be slow. For this upgrade the IOS with IPSECservice
tmssupport Sun, 10/12/2008 - 05:02
The network had been working fine until lately.
The IPVPN is provided by the ISP.
The routers are configured with BGP & OSPF for dynamic routing.
Below is the router config :-
interface FastEthernet0/0
ip address 192.168.20.24 255.255.255.0
no ip redirects
duplex auto
speed auto
standby 1 ip 192.168.20.34
standby 1 preempt
standby 1 track FastEthernet0/1
standby 2 ip 192.168.20.33
standby 2 priority 95
standby 2 preempt
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
no ip redirects
duplex auto
speed auto
router ospf 100
no log-adjacency-changes
summary-address 202.x.y.0 255.255.255.0
redistribute bgp 65000 subnets
passive-interface FastEthernet0/1
network 192.168.20.0 0.0.0.255 area 0.0.0.0
router bgp 65000
bgp log-neighbor-changes
network 192.168.21.0
network 0.0.0.0
timers bgp 10 40
redistribute connected
redistribute static
neighbor 202.x.y.217 remote-as 9255
neighbor 202.x.y.217 ebgp-multihop 3
neighbor 202.x.y.217 route-map MED-10 out
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.20.31
ip route 192.168.21.0 255.255.255.0 192.168.20.31
ip route 202.x.y.216 255.255.255.252 172.16.1.2
no ip http server
access-list 10 permit 0.0.0.0
access-list 10 permit 192.168.21.0 0.0.0.255
route-map MED-10 permit 10
match ip address 10
set metric 10
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
Please advise.
regards,
check cpu
show proc cpu hi
show proc cpu sort
check interface for error and duplex
show int | i rel
show int | i err
look and see if all arp entries have same timeout, they should all be varied
sho ip arp
check circuit utilization
set load-interval to 30 on all interfaces
check for DE bits if you have frame-relay
show frame pvc
configure netflow top talkers
configre ip nbar application discovery
verify there are no mtu problems
run extended ping from router to router at 1500 bytes with df bit set
post the output of all of this and I can probaly point out something
try also looking at the desktop its self, go throught and tune the OS to run faster, chances are they have a bunch or programs running in the background, themes, multiple personal FWs, click start then run and type in msconfig and go through and click on the startup tab and uncheck everything not needed, then click on services tab and stop the services not needed.
lastly turn on ip netflow top talkers and configure the load-interval on all interfaces to 30 so you can see if there are data bursting spikes, when there is a spike issue the show ip flow top command and find out what system and application is bursting. There are many ways to control bursting apps , CAR policy on interface would be easy
