Contact center express Co-Resident Bundle
Oct 11th, 2008
Hi all
the question is about CCX 4.0 co-resident installation with CM4.1.3.
We whant to install CCX 4.0 bundled with CM 4.1, but we have a 2 server CM cluster, not a single server.
How we can do it? How this affect the CM cluster? Best regards.
Overall Rating: 4 (1 ratings)
esa786_2 Sat, 10/11/2008 - 20:32
Hi. It is for production environment or Lab testing. You can install CCX 4.0 with CM 4.1.3 on the Publisher or Subscriber. If it is production better to have seprater server.if it is production, you have to check, whether cisco support the Co resident set up. I am using CCM 4.2 with CCX 4.0 on co-resident set up in my lab set up.
if it is usful Rate it.
Gem
arani Sat, 10/11/2008 - 23:24
Salve.
E 'per ambiente di produzione. La mia idea è quella di installare CCX (fornito in bundle con MCC casella) sul server editore. Non sono sicuro di eventi collaterali sul CM cluster. avete esperienza su questo.
Thank you
arani Sat, 10/11/2008 - 23:48
Hi.
this is production environment. My idea is to install CCX (supplied bundled with MCC box) on the publisher server. I'm not sure about collateral events on the CM cluster. have you experience on this?
Thank you
Chris Deren Sun, 10/12/2008 - 06:41
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
It is supported on the software versions you have, however only for up to the 5 seat bundle, so if you plan on expending your UCCX deployment beyond that you will need a dedicated server.
HTH,
Chris
esa786_2 Sun, 10/12/2008 - 22:49
Hi Chris. if i install in the separate server, do i have to get the license from cisco. if so i have to pay based on the number of seat license? The 5 seat means 5 agents or five ivr ports? pls explain
gem
Chris Deren Mon, 10/13/2008 - 04:53
  • Hall of Fame,
You got it.
Chris
esa786_2 Mon, 10/13/2008 - 05:04
Thank you Chris. Keep answering the forums questions and helping other.
regards
esa
