CUCM upgrade from 4.1.3 to 6.1 with 36GB HDD
arani
Hi all
We whant to upgrade our CUCM cluster 4.1.3 to 6.x, but our MCS server has only 36GB hard disk but 72 GB must be present for upgrade. someone know's steps to upgrade if we provide new 72GB hdd?
Thanks to all
yes that's right. since either way (new or same server) require to wipe out all the windows install and the usage of the DMA file to import all the info once you shut down the server you can insert the new HDD and make the RAID so you can start with the CUCM 6.x install, when prompted choose upgrade and point to the DMA file you got from the old version
java
if this helps, please rate
java
6 Replies 6
Adrian Saavedra
Level 7
Level 7
Hi friend,
If you need the steps to upgrade from CUCM 4.1.3 to 6.1 you can check this two URLs:
Upgrading to Cisco Unified Communications Manager Release 6.1(2) from Cisco Unified Communications Manager 4.x Releases:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/6_1_2/upgrd612.html
About Data Migration Tool:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/6_1_2/dmaug612.html
Hope this info helps for your upgrade.
- Adrián.
the steps to make upgrade are clear.
My issue is about Hard Disk on the server.
I'm searching for a workaround about this.
Thank you.
simply take the DMA from the server, replace the HDD and install the CUCM 6.X choosing the upgrade option
install disk will look for that HDD and if not provided won't work, also it's not supported to try to use less than that HDD
java
java
Hi Java
just to confirm i'm right.
Could you correct my steps?
1) Make DMA and all other pre upgrade steps
2) Pub server shutdown
3) Remove HDD and insert new HDD (make raid)
4) Install CUCM 6.X selecting Windows Upgrade
5) Apply DMA file.
Correct?
Thank You.
java
java
Ok Java
Thank you very much for your help and patience.
Best regards
