Use FXO ports instead of BRI ports
Oct 11th, 2008
Newbie to UC500 but experienced IP engineer: My model of UC500 has built-in BRI ports. I have purchased a VWIC2-2FXO card to use for the public switched network instead of the BRI ports. Cisco Configuration Assistant -> Configure -> Telephony -> Voice ->Device initially shows Built In: 4 FXS and Built In: 4 FXO. It then has a think about it and changes to Built In: 4 FXS and Built In: 2 BRI which is fine. However, it is only then that the panel below shows Public Switched Telephone Network and gives me the option of Basic Rate Interface BRI Switch Type. I can change this from the default Basic-NET3 to None but was hoping to see the FXO ports appear in the panel. Any assistance on FXO on VIC to be confogured for Public Switched Telephone Network would be appreciated. I have trawled various manuals but no joy so far.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Sat, 10/11/2008 - 22:07
to configure FXO
lets say u have fox port 0/0/1
and u want any call comes to this number to dial internal IP phon with number 1234
voice-port 0/0/1
connection plar-opx 1234
if u wanna forward this number to internal callmanger if u have internal callmanger u need voip dial peer like
dial-perr voice 91 voip
destination-pattren 1234
session target ipv4:[ccm ip]
UC500 like CME phones connect directly to it then no need for voip dial-peer
but u need dial peer as the followinf one
now if u wanna route calls to outside u can make the following dia-peer
dial-peer voice 9 pots
destination-pattren 9.T
port 0/0/1
the above dialpeer expect the user dial 9 folloowed by the pstn number the this dial peer will strip out the 9 and forward the rest of the dialed number
good luck
if helpful Rate
emrivera01 Sat, 10/11/2008 - 22:15
I just found out since we have ISDN/BRI, we need to upgrade our license to support the FXO card. So now we looking into setting up a SIP trunk and we are using to test, but having trouble with that as well.
