Cannot Ping local Subnet from ASA
Oct 12th, 2008
Can someone please check this config,
We have this asa5510 as our default gateway (10.0.0.1)
We also have a 2821 router running cme with two sub interfaces (10.0.0.3 & 192.168.100.1)
I have added a route on the asa to 192.168.100.0 but cannot ping to 192.168.100.1 from clients on the 10.0.0.0 network although I can from the asa itself.
Can you see what is causing this?
Chris
JORGE RODRIGUEZ Sun, 10/12/2008 - 04:46
  • Green, 3000 points or more
asa config seems fine
IN 2821 router do you have a route back to reach 10.0.0.0/24 subnet or a default route pointing to asa inside interface
i.e
ip route 10.0.0.0 255.255.255.0 10.0.0.1
or
ip route 0.0.0.0 0.0.0.0 10.0.0.1
if you do have above example already in 2821, can you gather asa logs while trying to ping 192.168.100.0/24 hosts from 10.0.0.0/24 network and post the logs.
Rgds
Jorge
shaw.chris Sun, 10/12/2008 - 11:45
I tried adding ip route 0.0.0.0 0.0.0.0 10.0.0.1 but still wouldn't work. Would it still need this route even though the 2821 has one of it's interfaces in the 10.0.0.0/24 network?
When I try and ping from the client 10.0.0.78 to 192.168.100.1 this shows up in the asa log
portmap translation creation failed for icmp src INSIDE:10.0.0.78 dst INSIDE:192.168.100.1 (type 8, code 0)
does anyone have an idea what could be causing this
Chris
shaw.chris Sun, 10/12/2008 - 13:54
I thought it may be to do with the ASA natting traffic to 192.168.100.0 so I added
access-list NONAT extended permit ip 10.0.0.0 255.255.255.0 192.168.100.0 255.255.255.0
It still doesn't ping but I get a different error on the ASA:
No translation group found for icmp src INSIDE:10.0.0.78 dst INSIDE:192.168.100.1 (type 8, code 0)
JORGE RODRIGUEZ Sun, 10/12/2008 - 17:39
Sorry for late reply..
invert the acl
remove
no access-list NONAT extended permit ip 10.0.0.0 255.255.255.0 192.168.100.0 255.255.255.0
rewrite statement with
access-list NONAT extended permit ip 192.168.100.0 255.255.255.0 10.0.0.0 255.255.255.0
then try from 10.10.10.78 pinging to any host on the 192.168.100.0/24 net
amady3381 Sun, 10/12/2008 - 21:00
Hi Chris
add these commands and it will work fine with you
same-security-traffic permit intra-interface
static (inside,inside) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 norandomseq nailed
static (inside,inside) 192.168.100.0 192.168.100.0 netmask 255.255.255.0 norandomseq nailed
sysopt noproxyarp inside
failover timeout -1
When you put these commands it will work fine.
shaw.chris Tue, 10/14/2008 - 00:47
Thanks for your help, would it be possible to explain what these commands are doing as well.
amady3381 Tue, 10/14/2008 - 01:03
Dear Chris
refer to the below link and you can find the answer:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&topicID=.ee6e1fa&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1d776
also you can have another solution if you put the default gateway for the users as the CME router (10.0.0.3) and point a default route on the router to the 10.0.0.1 (ip route 0.0.0.0 0.0.0.0 10.0.0.1).
thanks,
shaw.chris Wed, 11/05/2008 - 14:44
Thanks for your help.
Would this affect performance if all packets had to go through the router first rather than straight out of the ASA?
Also I have Site to Site VPN's set up that I wish to connect to the CME system e.g. 192.168.3.0 is a remote site. What steps would I need to take for this network to see the internal 192.168.100.0 network?
Chris
